Author Topic: Can this be used a probe isolator to an oscilloscope?  (Read 748 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
« on: February 04, 2022, 06:32:47 am »
Was on mouser and stumbled upon this DC-3GHZ isolator fairly cheap, can it be used as an isolator between the scope and the standard probe?
https://www.mouser.dk/ProductDetail/Mini-Circuits/Z7550-BMBF+?qs=DRkmTr78QASgPck0XOSDow%3D%3D
Datasheet: https://pdf1.alldatasheet.com/datasheet-pdf/view/1324771/MINI/Z7550-BMBF+.html
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Offline tooki
Re: Can this be used a probe isolator to an oscilloscope?
« Reply #1 on: February 04, 2022, 07:48:18 am »
But how is that isolated? On its schematic, it’s clear it’s not galvanically isolated.
Offline fcb
    • Electron Plus
« Reply #2 on: February 04, 2022, 09:13:40 am »
Impedance matching transformer. No isolation.
Online radiolistener
  • Country: ua
« Reply #3 on: February 04, 2022, 12:21:23 pm »
there is no isolation, it has direct connection between input and output ground
Offline jonpaul
« Reply #4 on: February 04, 2022, 01:00:01 pm »
Hello: Unclear your objective:
Isolate scope input 1 M from mains etc?
Pass DC...HF and convert 75 Ohm ><50 Ohm?
The Mini Circuits part is a Zo match with DC bias link eg for cable TV use. The transformer wthin has a LF point determined by the core, area and number of turns.
This should be designated for example as 10 MHz...3 GHz 75><50 Ohm match with DC bias link"
It is NOT a DC-3 GHz device despite the specs!
Suggest to read the Tektronix Circuits Concepts book "Oscilloscope Probe Circuits Concepts" to understand the different scope input and probe options.
https://w140.com/tekwiki/images/6/62/062-1146-00.pdf
If you can define precisely the system freq,min max (eg DC-100 MHz?)  and isolation needed the forum can assit you better,
Bon Chance,
Jon
Jean-Paul  the Internet Dinosaur
