I want to attenuate an input signal (audio frequencies) by an amount that I can vary; can I use a voltage output DAC for that, giving the signal at the reference input, or is there something in the design of voltage output DACs that requires the reference input to be constant?
Naively, a voltage output R-2R DAC should be like a digital potentiometer with one pin fixed to ground, right? At the same time, DACs offer more bits and specify lower glitch and digital feedthrough.
EDIT: There was a paragraph here about LTC2641, but I now realize it needs reference input above 2V, so it won't work the way I imagined. Other than that, what other issues should I know of?
