I bought a small mercury discharge tube recently, only to find it impossible to get a suitable ballast locally. I figured out that an approximately 8H inductor would be suitable for the 5W tube, but not something I can get hold of.
However, a suitably rated 1.5uF capacitor would also provide the required impedance and is easily (and cheaply) available.
Is there any reason ballasts are usually inductive? Am I missing something that would prevent the capacitor from working?
I suppose even a resistor should work, but the losses would be high.
