Author Topic: Capacitor Size Vs Rated Voltage  (Read 3147 times)
Offline BskitterTopic starter
  • Country: cz
« on: November 01, 2016, 06:10:26 pm »
Hey Guys so, I am replacing some old caps on a Kenwood Amplifier,
There are two caps I am replacing.
0.01 uF Ceramic +100% -0%
0.15 uF Mylar +- 10%
Now all was fine until I bought the replacement caps and noticed both are incredibly smaller than the old ones, here is a photo of the two side by side of the new ones
The top ones are 0.15 uF.
The replacement I bought is rated at 100V 10%
The bottom ones are 0.01uF (103), the big blue one is rated @ 3kV and the small blue one is rated at 100v 10%
Now looking at where they are located on the circuit the 103 caps are for some high frequency filtering of some sort, I have no idea why the caps that were put there are so big since the output on the TF is 50V RMS
On the other hand the 0.15uF caps look like some sort of snubber from the output of the `power transistors there is a 2 Watt resistor before the cap.
Here are the diagrams for both.
The parts sheet for this amp mentions nothing about the rated voltage for these capacitors only the tolerance.
Basically will the small capacitors be fine in this situation ?
Regards
Byron
Offline wraper
  • Country: lv
Re: Capacitor Size Vs Rated Voltage
« Reply #1 on: November 01, 2016, 06:21:03 pm »
First of all I don't understand why you would want to change them at all. And second why would you want to change them with crappy unstable ceramic capacitors  :palm:.
  • Country: cz
« Reply #2 on: November 01, 2016, 06:25:43 pm »
Well this is why I am asking kind sir, What capacitors are suitable if ceramic are "unstable" ?
Offline wraper
  • Country: lv
« Reply #3 on: November 01, 2016, 06:26:40 pm »
No, not fine. On top of that 0.15uF capacitor unlikely to be 100V rated. More like 25-50V. Never change film capacitors with ceramic, especially with Z5U or Y5V crap you bought.
Offline wraper
  • Country: lv
« Reply #4 on: November 01, 2016, 06:29:33 pm »
Not replacing them is the best. The is no good in changing them. Film capacitors should be replaced with film capacitors (if there is actual reason to do so).
Offline singapol
  • Country: sg
« Reply #5 on: November 01, 2016, 06:36:09 pm »
If none of the caps are shorted or open I think you can put them back where they belong.Have you measured their capacitance value and are they in spec?
  • Country: cz
« Reply #6 on: November 01, 2016, 08:53:13 pm »
Thank you for the info, but this is the beginners thread and I am just college student trying to repair my amp, no need for hate.
I tested the caps, one of the 103's is not picking up on the tester. Is the smaller 103 an acceptable replacement ? I doubled checked the product code vs the data on the suppliers site. its rated @ 100 Volts.
Is the size of the cap just old technology, and from till now we have made them smaller ?
Byron
Offline wraper
  • Country: lv
« Reply #7 on: November 01, 2016, 09:10:40 pm »
No and yes. They are smaller because of the newer technology but not only. Completely inferior parameters compared to the 0.15 uF film capacitor, likely lower voltage rating too. 10n capacitor most likely have lower voltage rating, original could be somewhere about 200V IMO. For AC you need at least twice of the DC voltage rating (+ some margin of course.)
Those capacitors are not good as replacements at all. And original 10nF capacitors certainly are not a source of the fault, even if they are faulty themselves, what is very very unlikely. More likely either you tried to measure it in circuit or there wasn't good contact between the capacitor and multimeter probes. They just don't fail unless something extraordinary happens.
Offline Rerouter
« Reply #8 on: November 07, 2016, 09:32:22 am »
C59 and c60 should remain film caps because they are in the signal path, equally they will be that size because they will dissapate some heat.
The other 4 near the bridge rectifier can be ceramic, and likely are not too critical to the operation of the device.
Offline danadak
« Reply #9 on: November 07, 2016, 09:55:52 pm »
Capacitor technology is a study unto itself. Here is an excellent starting
application note that will help.
The dielectric and geometry and construction make capacitors solve different
problems with different types, eg. the best characteristics. For example in noise
work ESR a very important parameter, ceramics, multilayer ceramics, polymer
Tantalum, etc.. Another focus could be leakage, where film, Teflon, polypropylene,
and others shine at low dielectric leakage. Then you have caps for timing circuits
where C vs V of the cap, temp drift.....you can easily make a career out of just
Capacitor technology. RF work has a whole technology area itself, air spaced, piston,
silver button mica,........
http://www.kemet.com/Lists/TechnicalArticles/Attachments/6/What%20is%20a%20Capacitor.pdf
The .01, .001, to ground, are typically for noise suppression. Usually ceramic disk.
Or these days multi layer ceramic (MLC).
Regards, Dana.
« Last Edit: November 07, 2016, 10:06:20 pm by danadak »
