Author Topic: Cheap oven to solder SMD components in Europe  (Read 2722 times)
Offline lilmantisTopic starter
« on: June 10, 2016, 02:21:14 pm »
Hi all, I will make soon some PCBs for an LED lamp and due to the dissipation of pads I think the only way to assemble them properly would be in an oven. Excluding an expensive assembly house of course.
Does anyone know if I can buy something already made from Europe?
Any suggestions for an controller and adapt an oven for it?
Offline danadak
Re: Cheap oven to solder SMD components in Europe
« Reply #1 on: June 10, 2016, 02:48:30 pm »
No small number of people have adapted toaster ovens, search the site for those threads.
Regards, Dana.
« Reply #2 on: June 10, 2016, 03:19:07 pm »
I was wondering if there is anything ready made that I can buy from Europe.
Online rstofer
« Reply #3 on: June 10, 2016, 03:30:29 pm »
I have a converted toaster oven but a hot plate works just as well if the board is small - say 2"x3" or so.  I used a GE Hotplate and just turned the power knob all the way up and watched for the solder paste to flow.
My toaster oven is a simple Black and Decker Infra Wave from which I gutted the controls and replaced them with a solid state relay and a PID controller:
http://www.rocketscream.com/shop/reflow-oven-controller-shield-arduino-compatible
I insert the thermocouple into one of the vias so that the controller sees exactly what the board is doing.
I also filled the cavities between the walls with high temperature insulation to make it easier to get up to temperature.
The hot plate is still a viable alternative...
Offline rob77
  • Country: sk
« Reply #4 on: June 10, 2016, 03:31:12 pm »
buy a cheap toaster oven - Severin makes some nice and cheap toaster ovens (i have the SEVERIN TO2054 - it's a tiny one) + buy a PID temperature controller + a temp sensor. and you have a crude but usable setup for reflow soldering.
if you plan to reflow only few boards a week then go for a hot air station.
Offline Fred27
    • Fred's blog
« Reply #5 on: June 10, 2016, 03:47:58 pm »
If you want something of the shelf then take a look at this. Really just a packaged toaster oven and PID controller.
https://www.beta-estore.com/rkuk/order_product_details.html?p=624
Offline savril
« Reply #6 on: June 13, 2016, 02:11:19 am »
You may be able to get an halogen oven. This oven use an halogen lamp and a fan beside disperse the heat evenly. Toaster oven use IR and have a tendency to overheat black parts and underheat PCB that is behind the metallic grid, ...
A basic one with 1400W power cost 50€. You can get these in France and UK easily (mostly by internet), I don't know if you can get those in Romania.
Take a look at http://andybrown.me.uk/2014/05/11/awreflow/ for an example. The guy made also another reflow controller which is more easy to duplicate and has a better "PWM" control: http://andybrown.me.uk/2015/07/12/awreflow2/ .
The temperature curve he get with his last setting is interresting :
« Reply #7 on: June 13, 2016, 01:17:05 pm »
Thank you all for the suggestions. It would appear that one project leads to another.
