I spend some time with one of these supplies. It initially looked great but as I got further into the project warts started to show up. If you build it as is, you will have trouble at the ends of the operational envelope. As an example, if you try to draw 3A with the supply set to 0.25V, you will very quickly find that, as it stands (out of the box, so to speak), it will be eager to let the magic smoke out. The suggested heat sink and the supplied pass transistor will NOT sustain the required 100W or so of dissipation. There are other problems too, but you can get them solved. Here's a list of things I found/did.
1) The supplied op-amps (TL081) are fakes (at least they were with mine) and even if they were genuine, the absolute maximum voltage is only 36V, however, with a 24V transformer they will be subject to 40V under low loads. To get passed this I went to a 20V transformer and dropped the expected output from 30V to 20V.
2) The negative supply Zener is 5.1V as supplied. I dropped this to 3.9V to further reduce the stress on the op-amps.
3) I replaced the fake TLO81s with real 741s for the current error amp and the voltage reference and used a real TL081 for the voltage error amp.
4) I changed R12 to 27k to set the max output voltage to 20V.
5) Changed R18 to 80k to reduce the maximum current to 2.5A
6) Changed the negative supply resistor (R2) to a 1/2 watt. The little 1/4 watt job will quickly burn itself up.
7) Massively increased the size of the heatsink and built a small temperature controlled fan for forced air cooling.
8 ) Added Coarse/Fine controls for both voltage and current
9) Added connectors for the fan, the pass transistor (which I mounted off board on the heatsink) and the current limit LED.
10) Increased the filter capacitor to 9,900uF (used 3 x 3,300uf Rubycons)
In the end I wound up with a highly stable and useable 0-20V, 0-2.5A power supply that will work reliably across it's entire operating envelope with essentially zero ripple and very decent response. I use this supply almost daily.
I did 6 videos on the process if you are interested in seeing my failures, fixes and final "triumph".
https://www.youtube.com/playlist?list=PLAoY7fARPMX_rywPLGCvLJU9BJl97MIJg
