thanks for all the contributions guys; now I have more confused ideas than before
Come on, I'm joking.
I see that many people despise thin pencil tips, but if they are produced there will be a reason, don't you think?
If I wish to heat ONLY a small spot, a pencil tip will be the preferred tip; I see that many use the tips cut at 45 °, interesting, but I think I can get the same results even with a flat chisel tip, of course you need to tilt more!
Looking at that video of welding (about 6 minutes), he saw that the heating phase is almost zero, I generally heat a little more, and in the end I stay with the tip 1 second more, it helps to not have cold welds and to obtain a nice final weld cone.
But as my father says,
I am a woman, it is already an excellent result to hold a soldering iron ...
