200 Euro is too much to pay for the Tek. Plus it only has 2 channels, is in "unknown" condition, and you don't mention whether it includes probes or not. The only way this would be a better choice is if you really cannot afford the DS1054z and absolutely need an oscilloscope right away. While I am a great fan of analog scopes, my feeling here is "if you have to ask, you should get the Rigol". As far as servicing goes, yes, you can encounter some real headaches should the Tek fail. If the Rigol fails, you have the vendor's and the manufacturer's warranties to rely on.
What do you mean when you say you've reached the limits of the DS1052? What do you expect the DS1054z to do, and why do you think the 2215a might serve your purposes better, or as well?
