Yeah, that MOSFET will do 200A according to page 1 of datasheet, but only in certain condition. Look at the graph.
If you exceed these ratings, after a few seconds, your MOSFET goes shorted Drain-to-Source.
+1
I've run controlled destructive testing on 100s FETs, to guarantee product reliability. ONE thing I can tell you for sure is - the graphs LIE !
Most the time, they are 20-50% over-stated and up to 100%. There is NO standard test methodology for SOA, each manufacturer makes up his own.
Even on a TO247 package with the highest grade insulator, I've never had >1sec before destruction. AND you need to read up on hot-spotting as well !!
eg You may calculate a SOA 8A at 50V, but it'll be 6A or 5A in reality. ALSO NOTE, once in SOA, you switch from PTC to NTC !! SO you get thermal runaway !
There are a few types specifically made for linear operation eg IXYS
This paper is an excellent start - ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20100014777.pdf
