A crystal is a start. But without trimming it, or compensating the frequency offset in software, you will find its accuracy being lacking, compared to what you are used from your wrist watch (while the precision is sort of ok). +/- 10 ppm are still almost +/- 1 second a day, 5 minutes/year.
Factory adjusted RTC ICs, like some of those from Maxim/Dallas are indeed a more accurate, worry free, solution, especially for a one-off. They are more expensive, but can give you 2 minutes/year accuracy.
A rather cheap solution are radio clock receivers. You sometimes get receiver modules very cheap. I think I payed 6 Euro for my last one, but that was a DFC77. I also happen to find separate, salvageable receiver modules in cheap battery operated travel alarm radio clocks.
Decoding the signal from such a module in software is usually simple and it is easy to adjust an internal MCU timer/counter with the result of the decoding. I would recommend to still have a running, crystal clocked timer/counter in the MCU to cope with signal loss. As long as you manage to get a radio signal once a day you can keep the timer/counter very accurate. Commercial consumer radio clocks do a similar thing. To save power they just turn on the receiver a few times a day to adjust their crystal clock.
