Author Topic: Clock pulse offset circuit?  (Read 2331 times)
Offline bitmanTopic starter
  • Open Source Guy jabbing with Electronics
« on: July 31, 2017, 09:03:07 pm »
I'm reposting - or maybe trying to remember to hit POST this time. IF for some reason my previous post on this was removed please let me know why.
In my TTL CPU project I need to create a derived pulse about 80ns shifted from the pulse I already have. I have a few chips like memory that can take that long to get output ready, so I need to split the clock between the "slower" chips. Unfortunately my google foo is not up to snuff here - I get a lot of patents on much more complex circuits creating 6, 8 or more separate frequency intervals. I like the idea of using flip-flops but I cannot find something that tells me how to calculate the time a flipflop takes.  I've also thought about the non-overlapping 2-phase frequency that seems a bit extreme though when all I want is a slight pause between the signals, and I would still like the "write" to be high/active while reading is going on.
I'm on a learning quest so I'm really looking for something to explain how things work, so I can understand why circuits would be designed this way, and figure out how to adjust it.  I did btw. try a few inverters and that only gave me about 20ns or so.  I don't have a ripple counter IC available, and I did find some materials that advised AGAINST using ripple-counters for this.
So I'm looking for sources can help me understand how to do this. Thanks.
Offline rfeecs
Re: Clock pulse offset circuit?
« Reply #1 on: July 31, 2017, 09:17:37 pm »
Try searching for delay line.
Online David Hess
  • DavidH
« Reply #2 on: July 31, 2017, 10:44:15 pm »
80 nanoseconds is pretty long for a gate delay or delay line but just about right for an RC network buffered by another gate; include a diode for a fast reset.  I suppose a couple low power TTL gates could be used in series but I think the RC delay is a better option.
« Reply #3 on: August 01, 2017, 12:19:31 am »
The chip I have is http://www.jameco.com/Jameco/Products/ProdDS/391822.pdf (CY62256LL-70PC). If I read the data-sheet correct, it has a 55-70ns response time? It's definitely a lot slower than the other TTL chips I have.  About the RC delay, maybe I designed it wrong but I didn't see a delay - and even worse, the pulse was not good enough to drive more than one or two chips at a time. I probably should look more at this again.
Is this the type of circuit you're talking about? http://www.ecircuitcenter.com/Circuits/opfil1/opfil1.htm
Online David Hess
  • DavidH
« Reply #4 on: August 01, 2017, 12:44:42 am »
That is the circuit but the amplifier is replaced with a logic gate.  For TTL, I think it needs like 3 RC time constants so like 1k ohms and 220 picofarads.  The values can be trimmed to get the exact delay that you want.
Offline rfeecs
« Reply #5 on: August 01, 2017, 12:49:16 am »
There's a temptation to say that if you need a delay you are doing it wrong.  The usual way to deal with slow memory is with wait states.  Assert the address lines, then wait some number of clock cycles before reading or writing.
For the RC delay, it would probably be a series R, shunt C, followed by s Schmitt trigger.  You need the Schmitt trigger to give you a good rise/fall time.
The following users thanked this post: bitman
« Reply #6 on: August 01, 2017, 12:51:26 am »
An additional question - does the wave form (sinus vs. square) make any difference?
« Reply #7 on: August 01, 2017, 01:07:33 am »
I was wondering about that, however it seems logical (excuse the pun) to time reads and writes differently?  Why have chips accept input when the state isn't ready?  Granted, what I am about to do will really limit the maximum speed of the clock and if this was anything but a demo system I would follow your advice. But my basic question is still, that having differently timed clocks for read and write make sense - take away the extreme time difference in my case?
Thanks I didn't have the Schmitt trigger on it before. I'll get on that.
« Reply #8 on: August 01, 2017, 02:44:51 am »
Thanks - this worked. Turned out my inverter was "just" that, not the schmitt version, which I had no clue I had a few off - so I simply had to replace my 7404 with 7414 and connect me RC and I very close. I changed the cap, and now the delay is long enough. Thanks.
How do you calculate the sizes of the resister/cap in this setup? Ie if I know the length and mA/Volt how can I determine the delay?
« Reply #9 on: August 01, 2017, 02:46:22 am »
So that's what I had, but I guess I m issed the Schmitt Trigger requirement because once I replaced my TTL it worked.  I'll ask you the same question though - what formula do you use to determine the values of R/C in this setup?
Online David Hess
  • DavidH
« Reply #10 on: August 01, 2017, 02:57:19 am »
Ultimately it is just the exponential curve from charging a capacitor through a resistor:
https://en.wikipedia.org/wiki/RC_time_constant
In practice a given type of logic will yield delay = K * RC where K depends on the input and output characteristics of the logic family. 1 * RC is one time constant of delay so designers often talk about 1.2 or 2.2 or whatever time constants.
