Its a high beta PNP transistor being used to manage power. The uP can run on any voltage from 3-6V- no regulator is required, this PNP just lets battery current flow when a button is pressed or when the unit is active. The diode D15 is used to allow the uP to keep power on after a button is touched, etc.
The designator T? is a designator for a transistor, not an IC. Its a PNP transistor that is used as a power switch. The transistor is a bit grunty because the LED's draw some real currents. Pin 1 is the base, pin 2 is the collector and pin 3 is the emitter. Normally the base is pulled up with the 12k. When any button is pressed,- T2 (an NPN) is turned on and pulls on the 1K, R29 to sink current turning the PNP on. Some thing with a beta of 50-100 and an Ic max of 500 mA peak, you can measure. Package is SOT-89-3. Shouldn't be hard, look at Digikey, Mouser, Farnell, etc.
