Author Topic: Component identification needed please  (Read 1316 times)
Offline GTATopic starter
« on: December 14, 2022, 04:33:47 pm »
I'm working to reverse engineer a vintage 90's two sided high current supply / metering / sampling board for work and this is the most complex (for me) board I have ever tried to reverse engineer. I'm muddling through it at my own pace but came across a couple of components I cannot immediately identify.
I know it's some kind of diode as it's labelled CR2 but is it a Zener diode of some sort? Or just a regular high current junction diode? IFF it's a Zener, do the markings identify it's specs?
As well, there are resistors highlighted in the pic and are a light blue colour. Does the colour mean anything like a tighter tolerance?
Appreciate any info a more seasoned fella can offer. Thanks.
It's all mind over matter. But if you don't have a mind, then it really doesn't matter.
Offline PA0PBZ
Re: Component identification needed please
« Reply #1 on: December 14, 2022, 04:48:14 pm »
First thing is a tantalum capacitor, 10 uF, 35 Volt. Blue smd resistors are (often) precision resistors, and looking at the values they don't seem to fit in regular ranges.
Offline Terry Bites
« Reply #2 on: December 14, 2022, 04:56:34 pm »
Yep
« Reply #3 on: December 14, 2022, 05:00:25 pm »
At first, I thought it was a cap, then I saw that CR2 symbol and it swayed me to believe it's a diode :P. In fact the CR2 designation is for the 6-pin LM285 - 1.2 voltage reference nearby.
Thanks for the info gents.  :-+
Online HwAoRrDk
« Reply #4 on: December 14, 2022, 09:40:53 pm »
WTF, SOIC-8 package for a two-pin voltage reference? Why on earth do TI make such a thing?
Offline Jeff eelcr
« Reply #5 on: December 14, 2022, 11:58:03 pm »
The bottom resistor is 10.0 ohms, 1% most likley.
I can not read the upper two?
Jeff
Offline tooki
« Reply #6 on: December 15, 2022, 07:38:55 pm »
Probably for thermal characteristics, if I had to guess. The old Nat Semi datasheet indicates that the SO case has over 40% lower thermal resistance than the SOT-23 version that’s not made anymore. That was before we had modern thermally optimized SMD packages, mind you.
