Im still a bit confused guys, I do understand that you have to have a closed loop circuit for electricity in series thats not what Im asking. Its not a basic question i am trying to ask. What i am trying to ask, is why when touching the + to another battery - electricity doesn’t flow?
You are assuming all positive terminals and all negative terminals are equivalent. They are not. You need to label the batteries #1 and #2 (first battery and second battery).
So, you can now label the terminals on the first battery as "Positive#1" and "Negative#1". You can label the other battery with "Positive#2" and "Negative#2".
Now, when you connect Positive#1 and Negative#1 with a wire, electricity can flow out of Positive#1, through the wire, into Negative#1,
through the battery, and back to Positive#1. The
through the battery bit is important. It is how the electricity gets back to the starting point (what closes the loop).
Draw this with a pencil on your diagram to be sure you understand it.So let's try the same experiment with the two batteries. Electricity can flow out of Positive#1, through the wire, into Negative#2, through the second battery, out of Positive#2, and...then where? Where has the electricity got to go? There is no wire attached to Positive#2, so there is a dead end. There is no circuit. Therefore no electricity can flow.
Draw this again with your pencil on your drawing. How can you get back to home after you leave the positive terminal of the second battery?
If you want a different way to think about this, think about a motorway with traffic flowing along it. Suppose there is an accident and the carriageway is blocked? All the traffic comes to a standstill because it can't get past. All flow of traffic is stopped. The same is with electricity. If there is no path forward, the flow is blocked and everything comes to a standstill.
Someone earlier mentioned about static electricity with balloons and such. Guess why it is called "static" electricity? Static means stationary, not moving. Same thing. If electricity hasn't got a path to follow, it is stuck and doesn't move.
