I recently acquired a big 1kVA autotransformer, one of those commonly used as a "voltage stabilizer." I would like to rewind it so I can use it as an isolation transformer in my lab. I have zero experience with transformer winding.
My goal is to achieve 220VAC, 50Hz output at around 5A. Five amps is enough, though more would be better.
The core is an EI192 type, measuring 192x160x80mm. The center leg is 64x80mm. The existing winding has four taps, each adding about 15VAC.
I also found an online calculator to help with winding calculations.
My questions are:
1. Help? in general?
2. Can I keep the primary winding and simply add a secondary over it, or should I completely rewind both primary and secondary?
3. I’d like to use aluminum wire instead of copper to reduce cost. Is that acceptable?
4. Should I add a non-continuous copper shield between the two windings (with proper insulation) to reduce capacitive coupling?
5. How can I determine the magnetic flux density of this transformer? Should I assume mild steel at around 0.8 T?
Hi there,
The saturation flux density for most power transformers is 20kG which is 2T. The design target though is usually 1.5T or less.
This is tested with a primary winding energized with a variac so you can turn up the voltage and watch the no load current or power. The power should be 25 watts or less for a 500 watt transformer. You might have a preference for a little more or a little less.
The calculation is:
Bmax=E/(4.44*F*N*Ac)
where
Bmax max flux density in Teslas,
E is the applied AC RMS sine voltage,
F is the frequency in Hertz,
N is the number of turns,
Ac is the area of the core in square meters.
If the primary meets that target and it tests ok, then the primary winding is good enough. If not, add more turns and test again.
Also calculate voltage drop with the intended load current and wire diameter. You don't want too much of a voltage drop but some is ok.
Aluminum wire would be used in low cost designs or lighter weight designs if it is possible.
For a one-off design, don't waste your time with aluminum wire.
You don't need a bobbin if you use layers of tape or fish paper and tape. Use corners on the sharp corners, which can be fish paper (2000v/mil insulation).
You need enough insulation between primary and secondary to meet the isolation voltage requirement. That would come from the type of tape and how many layers, and the layers should have overlapped edges.
You would need a foil separator between primary and secondary connected to ground if you expect high frequency noise or a noise sensitive load.
