Hi, I am going to be doing repairs to an old guitar pedal and in the process of learning how it works I was thinking of mapping the schematic out in eagle to learn more. Then I was thinking beyond this point. Maybe I will make my own clone of it and figured maybe I could use this as a chance to learn about SMD boards and components
What is the general process in converting PTH boards to SMD boards?
- Simulate in spice to find min/max voltages on components
- Simulate in spice to find min/max current through components
- Determine max power for components
- Find equivalent/valid components in SMD form
- Swap components out
- Redo traces
- Compact board layout
Does this sound about right?
Are there any good links on this topic that you know of?
In case it matters, this is the schematic for the pedal
http://www.geofex.com/FX_images/p180.gif
