Hi Thanks to all for reply.
@Fry : Sure, i have the entire fibre 24meters long that can i use for replace the cutted one. But this is the minor problem from my point of view, the problem is the cotrol logic, i have no specs, and also this 10kW module is a slave module part of a complete system that output 60kW CW.
@gyro : My Cnc is a 2500Kg 1500mmx1000mm YAG laser cutter from 2016, YASKWA servo, with german linear rails. The Chiller have a dual usage cold / warm setup (12kW cooling power). The control is Cypcut, on windows 10. Very rock solid machine, but for 650W YAG output, drain about 35kW!!!, it's a fails
I've also the laser pumping module, but have too low power and wavelenght it's not suitable for cutting. See the photo attached.
I've studied about 7 months the laser system, i'm aware that this is a very delicated and dangerous task, but i wan't to achieve the result. This 10kW module have 4 hours of run-time, it's new!!
Also changing the Laserhead, reusing the chiller, i can achieve a laser cutting power of 10kW With max 15kW of drain power, that can be enough for cut 30mm SS.
But the isn't too much leterature on oscillator, so someone know if the oscillator need to be drive for working correctly? Because i need to create my own control logic with talk with PSU on serial.
