Author Topic: Corrosion on LiPo Battery Cell Wire  (Read 999 times)
Offline MuhScopeBrokeTopic starter
« on: March 16, 2021, 01:32:50 pm »
I've been using a Turnigy 1600mAh 3S 30C Lipo Pack to power an automated sailboat for a few weeks now but last night I tried to re-solder a connection to the 2nd cell's parallel wire (not sure what else to call it) and ran into something weird. It was extremely brittle and coated in a white powder, essentially rendering it useless. None of the other wires were like this which leads me to believe that it is from some corrosion of the cell.
I've ditched the battery as I can no longer charge it but I would still like to understand what happened so I don't do it again. Any thoughts?
Online amyk
Re: Corrosion on LiPo Battery Cell Wire
« Reply #1 on: March 16, 2021, 01:37:11 pm »
automated sailboat
In salt water? That'll definitely cause corrosion on everything... but even moisture in general tends to do that.
« Reply #2 on: March 16, 2021, 02:13:53 pm »
I haven't actually used this particular battery in a wet setting yet so I can rule that out as a factor
« Reply #3 on: March 16, 2021, 02:25:05 pm »
Going to guess the wires are CCA wire, which will do this as the aluminium corrodes.
