I'm with you on this though, soldering a crimp terminal is fine if done by someone who knows what they are doing. You only get problems when idiots do it and allows the solder to wick down into the strain relief area. Which is easy to avoid if you know what you're doing. And most engineers do.
I think that's a wildly optimistic statement.
Technicians know what they're doing with regards to assembly methods. Engineers very frequently do not.
Crimping is not as electrically robust as a solder joint. There's a risk the wire may pull out even if crimped following the right procedure and with the right tool.
A
bad crimp is not electrically robust, and may risk wire pull-out.
A
good crimp
exceeds the robustness of a soldered joint, and the wire will break before it pulls out. A good crimp is a cold weld, with the strands and connector fusing to a solid piece of metal.
The correct tools will produce a good crimp every time. But that does require that the tool, contact, and wire are all perfectly matched to each other. That's why crimping is not always sensible for hobby use or other low-volume applications.
You have to 'trust' that a crimp is good because you used the correct tool to do the crimp and you followed the correct procedure. It's kinda like using a BGA in that regard.
There are test procedures. In proper crimping, periodic test crimps are made to verify crimp dimensions and pull strength. Some (but not all) crimp types allow each individual production crimp to be tested. But with a well-controlled process, it's not necessary.
The bare minimum is a ratcheting tool, since the ratchet ensures a particular amount of force has been applied before it releases. This introduces reproducibility into the process, so that a test crimp (which can be tested destructively) is representative of production crimps.
Nothing wrong with crimping and in many applications it's good and it's the best option.
Above, you make it sound like a terrible thing. But you're comparing poorly-executed crimps to expertly-executed solder joints.
But choosing to solder a crimp terminal is a valid thing to do, there's just risks involved that you have to be aware of.
Just because something is intended to be used one way does not automatically make it wrong to use it in a different way.
Some crimp terminals can, others categorically must
never be soldered. (I have seen some that expressly warn against it because of how reheating can affect the heat treatment of the contact spring itself.)
The issue, however, wasn't the question of whether to solder a crimp terminal instead of crimping it, but whether to crimp it
and then apply solder. If the crimp was done anything close to properly, adding solder to it will only make it worse.
The only thing worse than that is to apply solder (e.g. tinning the wire) and
then crimp it, since solder cold-flows under pressure, and will eventually loosen. (Solder-crimp-solder is basically just soldered, and you may as well skip the crimp.)
