I never found a good and affordable hand crimper for spades. These days I crimp and then solder and then heatshrink or slide on insulated sleeves. It’s a good way to be sure for low volumes.
Soldering is the worst option ever, not just for spade terminals, but for all stranded wire connections.
Spade connectors were made for automotive and industrial applications, meaning stress and vibration.
The stranded wire will eventually break at a point around 3 mm from the solder joint, in the area where solid (due to solder) turns to stranded.
This will never happen on correctly crimped connections.
"SN-48B" is the generic name for the crimp tool needed, but quality differs greatly. Check the jaws for definition/sharpness/precision.
Prices vary from $12 (crap) to $20...40 (OK to good).
Crimping with a good tool is a joy!
