Author Topic: Current output signal from DAC to differential voltage  (Read 2194 times)
Offline DanioIOTopic starter
« on: December 23, 2014, 09:15:23 am »
I have a DAC which outputs it current signal and i want to convert it to differential voltage signal so i can process it later. I would like to use differential amplifier and i figure out to circuits which one is the best for my application so should i use something else?
Offline bktemp
Re: Current output signal from DAC to differential voltage
« Reply #1 on: December 23, 2014, 09:29:06 am »
The second circuit should work.
This application note can help:
www.ti.com/lit/pdf/sbaa150
