Broadly speaking, a waveform analyzer is(was) a special type of oscilloscope with a strong focus on the most accurate reproduction of the waveform that is possible. This usually comes with drawbacks such as less possibilities in triggering, less memory depth & reduced input voltage.
They are generally aimed at engineers that work on transmission systems where the quality of the modulation (QAM for example) is of importance.
If you are looking to buy an oscilloscope for beginner purposes, you are far better off with an entry level Siglent /Rigol/Uni-T, they will all blow that DP6100 unit out of the water and come complete with probes. Waveform analyzers will typically have 16 or 24 bit bit resolution (vs. 8 or 10 bit on a entry-level scope). Obviously this eats much more memory, driving up the cost and CPU requirements.
That said, high end scopes have made waveform analyzers obsolete. Technology has advanced to the point where it is no longer necessary to make compromises to achieve high reproduction quality, so they are mostly a thing of the past.
