Author Topic: defective supercap?  (Read 1878 times)
Offline BrainyCapacitanceTopic starter
  • Country: aq
  • Brain Capacitance: 369uf-->sleepy dielectric-->1uf
    • TinkerCad (Circuits)
defective supercap?
« on: April 18, 2024, 01:01:51 am »
err... I need help. I bought these 10F 3V supercaps made by Cornell Dubilier off Mouser. on my first time testing one, my circuit shorted out. I checked the circuit, but nothing was wrong. the circuit is supplying 2.3v, at 1.5a max. and the supercap polarity was correct. so I checked that supercap with my meter on a 2v conductivity test. it gave me the "short circuit" signal. and then, I ran it through resistance mode, and it shows the resistance between the supercap's + and - is 10Ω. yep. 10Ω. so I thought maybe that specific capacitor was faulty. I grabbed another supercap and conductivity then resistance. same thing. but I think, since these are all-new and haven't been used before, maybe it's just a "sleepy dielectric" :=\. what do you think? if it is a "sleepy dielectric", how can I "wake up" the dielectric without frying my MOSFET or voltage reg? plz be gentle :-\
what test gear? oh, you mean that $3 Harbor Freight Multimeter? yeah! I got that!
Offline Kim Christensen
Re: defective supercap?
« Reply #1 on: April 18, 2024, 01:32:03 am »
Your ohmmeter is going to take a very LONG time to charge up a 10F super capacitor... During that time, its going to read as a very low resistance if it started out fully discharged.
Charge it via a resistor to limit the current. Or use a power supply with current limiting that can handle a continuous short.
« Last Edit: April 18, 2024, 01:33:43 am by Kim Christensen »
The following users thanked this post: amyk, wraper, BrainyCapacitance
Offline amyk
« Reply #2 on: April 18, 2024, 01:44:36 am »
You can use a 3V incandescent bulb to limit the current when charging and provide an indication of the charging progress.
Online wraper
  • Country: lv
« Reply #3 on: April 18, 2024, 01:45:19 am »
So do you expect it charging in milliseconds? If circuit has no charging current limit, supercapacitor will basically cause a short circuit.
  • Country: aq
« Reply #4 on: April 18, 2024, 01:59:09 am »
that "circuit" wasn't my ohmeter
  • Country: aq
« Reply #5 on: April 18, 2024, 02:01:37 am »
what do you mean "has no current limit"
Online wraper
  • Country: lv
« Reply #6 on: April 18, 2024, 10:58:05 am »
It means you connect it directly to constant voltage power supply. If it's a switch mode supply, most likely it will just go into protection, try restarting, go into protection again.
« Last Edit: April 18, 2024, 11:03:30 am by wraper »
The following users thanked this post: BrainyCapacitance
Online coromonadalix
« Reply #7 on: April 18, 2024, 11:28:53 am »
charging a supercap can take a very long time,  in some case it will appear as a dead short
i usually use them in clock related stuff  or clock backed up  mcu  etc ...   i use an resistor  to drop the inrush it create,  sure it create a time constant, a simple diode and a resistor on the clock ic  ....
for an 1.5 farad at 5v   it take at least 15 mins to charge it,  and keep 1 week of clock
10 farad is a lot ... i mean a lot  loll
for sure    you don't use that to filter out an psu  ??
« Last Edit: April 18, 2024, 11:33:28 am by coromonadalix »
  • Country: aq
« Reply #8 on: April 18, 2024, 02:31:47 pm »
BTW, here is the schematic of "the circuit" that shorted out because of the sleepy Supercap:
I am just a starter at electronics, so please tell me if this circuit is bad gently
  • Country: aq
« Reply #9 on: April 18, 2024, 03:19:18 pm »
okay, so something like This?
Online wraper
  • Country: lv
« Reply #10 on: April 18, 2024, 06:24:05 pm »
Both circuits are totally nonsensical. No surprise it doesn't work.
Online Gyro
« Reply #11 on: April 18, 2024, 06:27:22 pm »
Just FYI, the OP is a 16 year old.
Best Regards, Chris
Offline bdunham7
« Reply #12 on: April 18, 2024, 07:32:42 pm »
What do you want the circuit to do?  The easiest way to charge your supercap is to use a voltage supply and then a series resistor to limit the current.  For a supply putting out 2.3V, a 10-ohm resistor would limit the current to 230mA maximum.  Your supercap will take a bit of time to charge.
Offline CaptDon
  • Country: is
« Reply #13 on: April 19, 2024, 02:20:49 am »
You got parts delivered to Antarctica from Mouser?? It's a pain in the ass to get them to Iceland! When first applying a voltage to any capacitor it will appear as a dead short if it is in an energy storage type circuit. You have to current limit the charge with a simple resistor.
  • Country: aq
« Reply #14 on: April 19, 2024, 03:45:27 pm »
err... I'm not ACTUALLY in Antarctica. I just chose it for "safety reasons". I hope you can understand
