Hi all,
I've read the hex file from a PIC18LF2420 and wrote it to a PIC18F2420 but the latter does not work as expected.
When I put the original PIC18LF in its place the circuit works fine.
What would be the so critical difference between these two?
I read that the LF has an eeprom type rom vs a flash on the F.
Can one work in place of the other or they're incompatible?
Thanks.
