Author Topic: DIL socket pin spacing  (Read 3990 times)
Offline veedub565Topic starter
« on: March 16, 2017, 06:09:37 pm »
Why is it that whenever you buy a DIL IC, the pins are always spaced too wide to fit into the DIL IC Sockets ? and then you have to bend them to fit. Is there an easy way or tool for bending all the pins to the right spacing ?
Offline drussell
  • Hardcore Geek
Re: DIL socket pin spacing
« Reply #1 on: March 16, 2017, 06:21:19 pm »
Did you even try to search for "IC pin straightener" ??   :)
Offline bsudbrink
« Reply #3 on: March 16, 2017, 06:27:34 pm »
To answer your first question, it is to give a little friction to the pick-and-place machines that used to (still do?) handle them.
The following users thanked this post: veedub565
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: March 16, 2017, 06:31:57 pm »
Not so much that, but so that when placed into the PCB, the pins spring back to hold them in place before wave soldering.
Day Job: Mostly LEDs
Offline bsudbrink
« Reply #5 on: March 16, 2017, 07:38:20 pm »
Well, I won't swear to it, but I'd bet you a beer that if you put those chips through a pin straightener and ran them through that machine again, it would fling a few across the room.  Or, at least, drop a couple on the floor.
« Last Edit: March 16, 2017, 07:40:30 pm by bsudbrink »
Offline rstofer
« Reply #6 on: March 16, 2017, 07:44:37 pm »
I lay the row of pins on my table and push/roll the package a bit.  Then I do the other side.
« Reply #7 on: March 16, 2017, 08:01:23 pm »
No I didn't even try to search for a pin straightener, I've got one, it straightens the pins, they still don't fit the DIL socket. Maybe mine is the wrong one?
« Reply #8 on: March 16, 2017, 08:09:13 pm »
Mine just puts the IC pins through a set of rollers, it's good if you have odd legs sticking out, but it doesn't make them fit the DIL socket. I;ll have to try one of the Ebay ones, looks like they work differently
Offline Howardlong
« Reply #9 on: March 16, 2017, 08:19:16 pm »
Precisely, I've been doing exactly that for over forty years, I don't see any need for a tool to do it.
Offline RoGeorge
« Reply #10 on: March 16, 2017, 08:32:29 pm »
Just place the DIL case sideways, on a flat surface (desk), with the exterior side of the pins touching the desk.
While the full row of pins is touching the desk with their thick size (near the case), slightly push the case to bend all the pins at once, so the whole row of pins will become 90 degree bent relative to the case. Do the same with for the other row of pins.
With a little practice, it'll take just a couple of seconds.
It can be done manually very easy for any DIL4 to DIL40.
The only real problem for the sockets were some Russian chips that used 0.787'' instead of 0.1'' pin spacing (2mm instead of 2.54mm).
« Reply #11 on: March 16, 2017, 08:37:40 pm »
Yeah I have been doing them manually in the way that you describe. Taking me a few goes to get it right though, I'm sure I bend one side more than the other too. Always terrified of breaking the pins
Offline Lovely_Santa
« Reply #12 on: March 17, 2017, 10:07:50 am »
I use 2 methodes to resolve this problem:
1) I use pin headers, I find in easier to put them inside a header than into the board directly, and you can replace them when broken/reuse (I do this for prototyping/breadboarding)
2) In my pcb libraries I have 2 different layouts, 1 with the normal spacing and 1 with an extra 0.2mm between the pins, so when I let them assemble my pcb, I use the normal spaced layout, but when I make my final prototype i won't use a pin header, but use the bigger spaced layout for my IC's and solder them directly on the board...
English is only my 3th language, so don't tell me my english is bad, becose I know that, I try to do what I can...
Offline tautech
« Reply #13 on: March 17, 2017, 10:25:29 am »
You won't, they're as tough as old boots.  :)
To break one off you'd need to grab it with pliers and bend in back and forth a few times, nothing like the little nudge to get them to 90 degrees.  :-/O
Avid Rabid Hobbyist
Offline rrinker
« Reply #14 on: March 17, 2017, 05:36:15 pm »
 Once long ago I had a Radio Shack insertion tool with a pin straightener - good up to 16 pin chips because that's all the wider the inserter blades were. Of the years I misplaced it so all I do any more is just roll them against the table.
 The one thing I learned as a wee player (and maybe what prompted me to get the Radio Shack tool) was you do NOT stick one side in the socket and push the whole thing over to get the second side lined up. After pulling the second chip out of the biological socket (aka my thumb) I wised up.
