Author Topic: Diode bridge  (Read 1693 times)
Offline RemondepemonTopic starter
Diode bridge
« on: August 12, 2014, 07:23:27 pm »
Hi everybody,
I am building a power supply that needs 26V power for the analog part.
Then, there is other stuff that runs on 12 and 5V.
I could just use an 7812 & 7805 for it, but I don't want to dissipate so much heat.
Plan B: What about using a transformer that has an extra pin in the middle?
Then I need a transformer of 2x9 = 18V.
For the high voltage stuff I use 2 secondary coils and for the low voltage stuff just one of the coils.
Here is a schematic, can anybody please tell me if this will work or there will be smoke?
Thanks!
Re: Diode bridge
« Reply #1 on: August 12, 2014, 07:28:21 pm »
whoops, an error in the schematic!  |O
Online T3sl4co1l
    • Seven Transistor Labs
Re: Diode bridge
« Reply #2 on: August 12, 2014, 08:05:52 pm »
Not smoke, but if you put a cap on it, you'll get 26V+ again.....
Take a close look at what the diode bridge is doing.  The CT alone will be at 13V relative to the one-side-grounded bridge.
Seven Transistor Labs, LLC
Re: Diode bridge
« Reply #3 on: August 12, 2014, 08:21:04 pm »
Tim,
I started to draw two separate bridges and discovered that 2 diodes were parallel. I deleted these two and then this schematic what there.
What do you mean by CT and what would your advise be?
Remon
Online T3sl4co1l
Re: Diode bridge
« Reply #4 on: August 12, 2014, 08:37:47 pm »
CT = center tap, the middle of the winding.
