Schottkey diodes have a very low forward voltage drop, they are good in clipping circuits (if external diodes clip the signal before the internal ones, your device wont need to shunt any current through it, also are good for higher efficiency rectifiers, (lower drop means less wattage for given current)
zeners give a stable voltage drop when given a stable current source, far better than a resistor divider, worse than modern reference IC's, though when around 6.3? - 6.4V? has nearly no temperature offset, and at other voltages can be used in temperature compensation, as most follow a rather static charachteristic, though with way they go, i have also forgotten,
as for the rest, lack the knowledge to summerise,
