You could go to aaalll this trouble to make a variable-height desk. Or, you could just get a tall chair so that when you sit on it, your head is at the same height as when you are standing.
So I looked around for DIY projects that could make something similar to what I wanted.Did find a lot of different solutions for it.
Is it worth making it a DIY project? I don't know where in DK you're from, but this height-adjustable table is given away for a bottle of wine.
The desk in your first video has a handcranked scissor lift mechanism. You could make something similar but instead of a handcrank it could be powered by an electric motor that drives one or two jackscrews.The motor can be controlled by a simple switch forming an H bridge.How powerfull such a motor would need to be would depend on how much weight you want to lift and how fast you want to lift it.
First I wasn't so glad of the idea, since I can't know if the setup could hold all the weight.Or if I could make it, since it is a little my advance than what I was thinking.But then I made a 3D model of the project and saw how unsecure the design was, when you compare it to the scissors model.
Exactly. A fixed height work surface will always handle weight better and be more stable than an adjustable one.
Quote from: David_AVD on May 24, 2015, 11:10:54 pmExactly. A fixed height work surface will always handle weight better and be more stable than an adjustable one.Always? What about a hardwood panel bolted to a forklift?
Wether it can hold the weight depends on how sturdy materials you choose.With a bunch of math you can analyze how the forces are distributed.http://www.engineersedge.com/mechanics_machines/scissor-lift.htmhttps://andreacollo.wordpress.com/2012/09/18/scissor-lift-jack-equations/Design for a higher weight than expected and add some extra tolerance to the parts and things should be fine.
.http://www.engineersedge.com/calculators/scissor-lift-bottom-loaded.htmI'm unsure what weight measurement it use, and how to convert Ry to Kg.
