You probably dont need to run the leds from anywhere near 20mA (unless your doing some sort of led display).
If its just for some sort of indicator light you can get away with much less.
Most people drive normal 5mm leds at around 20mA but if you get a narrow beam high intensity
green led and run it at 3mA while looking directly at it, even from 1 meter, its damn bright.
This is because the human eye is quite sensitive to green light.
Have a play with a few green leds on ya psu at 1-20mA and see what brightness you get. The high mcd / high intensity leds will seem brightest for less current.
But really, since you have 2000 of these 9572 chips, i'd just build a quick and dirty prototype thats driving the leds with whatever current you want and if the chip dies grab another one and try again at a lower current
It really is something you need to work out before you can design your real circuit.
