Hello!
I am here again with my study of tAoE. This time I think I understand the circuit (see pic below, otherwise is pic 3.99C), but I don't know about the timing.
So what I'm thinking is this. I will exclude the pass transistor (Q3) from the analysis since it's simply driven by Q2.
StartupThe gate of Q1 is high, due to the 220k pullup R3. this makes its drain low since it's pulled down by R2, and so Q2 is off. This means that no voltage is dropped across R3 or R4. C1 is discharged so both of its terminals sit at GND.
First button pressWhen the on/off button is first pressed current rushes through R3 to C1. Actually the voltage that "wants" to be set at the nongrounded terminal of C1 is given by the divider formed by R3 and the series of R1 and R2 (at least until Q1 starts conducting). Since R1 is big wrt R3 it's almost negligible I think (around 2%?).
Anyhow now this voltage is dropped across R3 with two effects: one is charging the cap, the other is pulling Q1's gate. So Q1 starts conducting and pulls its drain high. This should have two effect: one is basically pulling up the R1 right terminal, so that current charges the capacitor even through that resistor, and second Q2 starts conducting, thus pulling low its drain.
Now the R3 and R4 split the rail voltage roughly in half.
When the button is released the capacitor stays charged/trickle charges through R1 (actually I think that it discharges a bit through R1 and R2, and then recharges through R1) andQ1 keeps conducting due to its gate being at -Vcc/2 wrt its source.
Second button pressWith the second button press C1 which is at vcc, gets connected to Q1 gate which starts shutting down; in the meantime C1 discharges through R4 to ground. But Q1 shutting down shuts down Q2, thus restoring the original condition.
questionsI recreated the circuit (albeit with a different p-fet for Q1) and I measured with the scope the charge and discharge time of C1, finding a ~1us of charging time and around 500uS of discharge. I cannot find why though. I mean no RC value gives me that. I mean, I understand that the charging is done kinda regeneratively so it "rushes", but I don't understand the timings.
Second, I think my analysis is wrong, just because when the cap is discharged, it should start charging up again, since we're in the starting condition.
Can someone please help me? Cheers
