Author Topic: Does anyone know Japanese?  (Read 7659 times)
Offline alank2Topic starter
« on: July 12, 2017, 06:32:39 pm »
I'm trying to contact a guy in Japan through a webform and I don't know what to put in!!!
Offline PA0PBZ
Re: Does anyone know Japanese?
« Reply #1 on: July 12, 2017, 06:41:37 pm »
It looks like a standard captcha, so I guess you have to type in the text with the blueish background. So even if you could read it you are a bit out of luck...
The following users thanked this post: alank2
« Reply #2 on: July 12, 2017, 06:45:25 pm »
I translated the bottom part:
Please enter the letters written in the picture with numbers.
Example) "Ichi ni san" ? "1234"
? Please input in half size numerals.
Even I remember Ichi=1, ni=2, san=3, but that isn't helping me much!
I don't know what a half size numeral is either...
Offline PA0PBZ
« Reply #3 on: July 12, 2017, 07:06:33 pm »
I'm sure someone will respond with the correct translation, but then if you go back to the site the captcha will be different  :palm:
« Reply #4 on: July 12, 2017, 07:11:54 pm »
It seems to be staying for now, but you are probably right it will say "expired" when I try to submit it later...
Offline PA0PBZ
« Reply #5 on: July 12, 2017, 07:16:59 pm »
I see a 6 in your picture, but the others  :-//
« Reply #6 on: July 12, 2017, 07:19:50 pm »
I appreciate that you like a good challenge!!!  Thanks!!!! :)
Offline cdev
« Reply #7 on: July 12, 2017, 07:20:31 pm »
I had a situation like this once that I solved using a screencap and OCR under linux. I forget what program I used but there are a bunch of OCR programs that work in CJK languages, screencap, import into OCR, then Google translate?
Offline PA0PBZ
« Reply #8 on: July 12, 2017, 07:21:59 pm »
Oh and by the way, half size numerals = half width numerals or better: the way we use them, so just 1234 should do.
« Reply #9 on: July 12, 2017, 07:24:39 pm »
I tried a couple of image translation sites; no luck.
I'm not following - what is a half width numeral?
Online Andy Watson
« Reply #10 on: July 12, 2017, 07:26:43 pm »
Nightmare - Roman text captchas are bad enough.
I would guess that half size numerals mean lowercase - this is usual for captchas (I found that out the hard way!).
Assuming that they must be individual characters that can be typed on a keyboard - does this help:
https://www.branah.com/japanese
Offline PA0PBZ
« Reply #11 on: July 12, 2017, 07:36:47 pm »
That is what we type if I understand it correctly, so use 1234 or 4731 or whatever the original captcha shows.
Offline helius
« Reply #12 on: July 12, 2017, 07:38:03 pm »
half-size are normal ASCII numerals. See https://en.wikipedia.org/wiki/Half-width_kana
it looks like you only need the numerals from 0 to 9 (larger values are different).
PA0PBZ: the image you posted are the kana for pronouncing the numbers. They would not be written that way.
« Last Edit: July 12, 2017, 07:39:37 pm by helius »
Offline PA0PBZ
« Reply #13 on: July 12, 2017, 07:42:50 pm »
Maybe not, but they look similar to what is in the captcha  :-//
If you look at the example they give for 1 2 3 4 I can find these in the image I posted.
« Last Edit: July 12, 2017, 07:45:07 pm by PA0PBZ »
Offline Nusa
« Reply #14 on: July 12, 2017, 07:50:11 pm »
Correct, the captcha seems to be using phonetic spelling, at least in part. I don't know the first bit, but I clearly see "roku" and "zero" (6 and 0).
It's been over 40 years since I was in Japan, and I had only a basic knowledge of the language even then.
Offline PartialDischarge
« Reply #15 on: July 12, 2017, 08:04:27 pm »
It seems they are using both katakana and hiragana, studied them loooong ago
ichi roku roku zero
1 6 6 0
« Last Edit: July 12, 2017, 08:06:14 pm by MasterTech »
Offline Ton
« Reply #16 on: July 12, 2017, 08:09:36 pm »
You almost got it right PA0PBZ ans MAster tech got it in one  :)
You wrote it like  japanese normaly write it using Hiragana, but some of the capcha is Katakana, to make it less machine readabel
see atatched table
« Last Edit: July 12, 2017, 09:23:38 pm by Ton »
« Reply #17 on: July 12, 2017, 08:11:39 pm »
It gave an error, probably expired.
new one:
« Reply #18 on: July 12, 2017, 08:13:41 pm »
8993
Use this table together with the other one above
https://en.m.wikipedia.org/wiki/File:Table_katakana.svg
« Last Edit: July 12, 2017, 08:19:20 pm by MasterTech »
Offline CaptainNomihodai
« Reply #19 on: July 12, 2017, 08:14:48 pm »
8660
Edit: didn't see the new one, 8993 is right
« Last Edit: July 12, 2017, 08:17:48 pm by CaptainNomihodai »
« Reply #20 on: July 12, 2017, 08:20:54 pm »
I tried 8660...
Another new one:
thanks everyone!!
« Reply #21 on: July 12, 2017, 08:23:59 pm »
1314
« Reply #22 on: July 12, 2017, 08:27:24 pm »
I appreciate the help, it came up with an error which translates to:
? not post of alphanumeric characters only is accepted.
I should be clicking the LEFT button, right?
Another:
Offline Ton
« Reply #23 on: July 12, 2017, 08:34:26 pm »
8111
left button send   right button cancel
« Reply #24 on: July 12, 2017, 08:35:41 pm »
It responds with:
translate:? not post of alphanumeric characters only is accepted.
