Author Topic: Dual SCR vs single TRIAC to switch on Inductive load  (Read 3552 times)
Offline anishkgtTopic starter
  • Country: qa
    • George Hobby
« on: August 10, 2017, 09:12:25 pm »
What would be an ideal switch to control an Inductive load, Dual SCR or a single TRIAC ?
I was using TRIAC to switch a MOT at the peak of a sine wave. Then i read that some use Dual SCR's to control inductive load as that is how its done in an industrial environment. Can it be said Dual SCR design is the old way of controlling an ac load and TRIAC being bi-directional was the newer version to SCR's.
From a design perspective, a TRAIC uses less space and fewer components compared to a dual SCR design. Would that be all ?
Offline schmitt trigger
  • Country: mx
Re: Dual SCR vs single TRIAC to switch on Inductive load
« Reply #1 on: August 10, 2017, 09:30:31 pm »
SCRs would have fewer loses.
But most importantly, as they conduct in a single direction, they would not be re-triggered by high dI/dt
Offline Circlotron
« Reply #2 on: August 10, 2017, 10:06:36 pm »
Triac should be good enough for a MOT provided you have good enough snubbing. SCRs have the advantage of greater tolerance to dv/dt as well as much greater surge current capability.
  • Country: qa
    • George Hobby
« Reply #3 on: August 10, 2017, 11:09:10 pm »
Thanks guys the dv/dt is a sure thing to bear in mind when the load is highly inductive. I guess then my design with the dual SCR would be correct.
Sent from my iPhone using Tapatalk
Online Zero999
  • 0999
« Reply #4 on: August 11, 2017, 07:44:30 am »
The only disadvantage of SCRs is they don't trigger on all quadrants. The gate needs to be positive whilst the anode is positive.
Offline oldway
« Reply #5 on: August 11, 2017, 07:47:42 am »
This was true a few years ago, but with new developement and improvement of 3 quadrants (snubberless) triacs, it has changed.
The new technology snubberless triacs has high dv/dt, as high as scr's.
There is no reason to use dual scr, a single snubberless triac can do the same job with the same reliability and is easier to trigger  than dual scr's.
« Last Edit: August 11, 2017, 07:50:01 am by oldway »
  • Country: qa
    • George Hobby
« Reply #6 on: August 11, 2017, 08:03:39 am »
Yea snuberless was something that I had in mind as well but wasn't sure if I should stick with the old way or snuberless.
Offline oldway
