The second formula is a very special case. It's completely lacking vectors (namely, B, v and l are properly all vector quantities!), and uses only one angle. So it seems to assume velocity perpendicular to B, to get the maximum value of the remaining vector product. (E is also a vector quantity, so E = v x l x B makes sense.)
(EMF typically being a scalar, means taking the magnitude. Which is only appropriate when a direction has been solved for, which usually means integrating along a winding or something like that. Properly, the path has to be a closed loop, which a segment isn't even!)
Most important is that the CT's winding cannot move through the flux, because the flux is largely contained within the core, which moves with it. That might help your mental picture.
If we talk about the situation without a core, i.e., a Rogowski coil, then we should talk about each segment of the winding.
1. We can ignore the solenoidal component, because this component of l is parallel to the magnetic field, so l x B = 0. (Consider a conventional, single pass winding on a toroid form. Consider what the winding looks like if the form thickness goes to zero: rather than a toroidal helix, it's a toroid itself. And therefore makes one turn through space, parallel to the B-field from the current-being-sensed wire. This solenoidal component can be opposed by making a two layer winding where the winding pitch reverses at the end, so it doubles back on itself, or by placing the lead-in wire beneath the winding-in-progress, so both leads end up at the same end of the winding when complete.)
2. That leaves two directions. For a toroid of rectangular cross section, we have four segments: (1) the innermost segment, which is parallel to the central wire, closer to it, and going in the same direction (say); (2) the far end, where the turns are radial, rising from the inside to the outside; (3) the outermost segment, which is parallel to the central wire, farther away from it, and going in the opposite direction; and (4) the radial returns from outside back to inside.
3. The radials (2) and (4) are equal and opposite, so can be ignored as well. They are displaced by the height of the toroid, but the field is uniform along the axis, so that makes no difference. (If the field were conical somehow, there would be a difference. But it's rather hard to get a decreasing current along a wire.*)
(*Unless the wire is delivering a displacement current into free space, i.e., its electrical length is comparable to the frequency of AC going through it. But outside of antennas, we don't need to make this modification to Kirchoff's.)
4. That leaves the inner and outer segments. The inner segments (1) are closer to the central wire, and therefore see more induction than (3) outside. (This is how a current transformer normally operates.)
If we displace the assembly with axial velocity, then we have l x B = 0 for the solenoid component (still), v x l = 0 for the inner and outer segments (1) and (3), and v x l x B != 0 for the radials (2) and (4) but they still oppose exactly, for the same reasons.
So the correct answer is again 0, as well it should be.
Note that I've applied the second formula as such, taking some liberty with its definition (using the more general vector form, hopefully to be more illuminating than cryptic), and applied it to the same problem, straight line segments of length l. The segments are arranged into a winding, so that we can properly sum (integrate) a (scalar) EMF for the total winding, which is what we are looking for.
