Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
E-Z-Hook "mini-hook" Test Clip - How to attach a wire?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: E-Z-Hook "mini-hook" Test Clip - How to attach a wire? (Read 1227 times)
Doc Readout
Newbie
Country:
on:
August 25, 2021, 08:45:53 pm »
This is probably a really dumb question, but I had a test lead break on one of these
E-Z-Hook test clips
and I don't see a way to re-attach it as the top appears to be glued on. Does anyone know?
Logged
Wallace Gasiewicz
Super Contributor
Country:
Re: E-Z-Hook "mini-hook" Test Clip - How to attach a wire?
Reply #1 on:
August 25, 2021, 09:11:52 pm »
I think you pull the top off
Logged
jpanhalt
Super Contributor
Country:
Reply #2 on:
August 25, 2021, 09:22:55 pm »
Maybe this will give a clue:
https://ezhook.wpengine.com/wp-content/uploads/2019/11/X100W.pdf
When a hammer or wrench don't seem sufficient, RTFM (read the field manual).
Logged
bob91343
Super Contributor
Country:
Reply #3 on:
August 25, 2021, 09:58:17 pm »
I am also seeking info on how to solder these. The data sheet offers no help. I need to know how to route the lead wire, what soldering technique to still allow clip to move, etc.
Logged
ledtester
Super Contributor
Country:
Reply #4 on:
August 26, 2021, 02:16:56 am »
What's everyone's opinion of this technique?
How To Build J Hook Jumper Wire Test Leads / Mini Grabber Test Clips - John Salt
https://youtu.be/_yH9ytNSG4U?t=3m40s
Doesn't make use of the slots in the end.
Logged
Doc Readout
Newbie
Country:
Reply #5 on:
August 26, 2021, 04:27:55 am »
Thanks, all... the entire EZ-Hook "bulb" top does indeed just pull off. It looks like the lead wire was originally crimped on, so just laying the newly stripped wire directly on top of the old crimp and soldering it should work fine.
Last Edit: August 26, 2021, 04:30:25 am by Doc Readout
Logged
jpanhalt
Super Contributor
Country:
Reply #6 on:
August 26, 2021, 09:50:37 am »
I would suggest a little strain relief, like a short piece of heat shrink tubing. I would also remove the old, probably open the crimp, and then solder my wire.
Logged
Doc Readout
Newbie
Country:
Reply #7 on:
August 26, 2021, 08:07:06 pm »
Adding heat shrink is a good idea. The crimp on mine looks like it would be tough to open & re-use without damaging the lead post, though. The crimp is nearly mashed down flat and the post metal looks pretty fragile.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
