Not sure what the choice entails/requires in the way of class choices and curriculum trade offs but why not try to do both to a strong extent? No doubt digital signals ride on analog/RF carriers. Whether you declare one or the other your emphasis it would be good to learn as much as you can about both. Look for opportunities to learn about the intersection: mixed use, modulation, multiplexing, A to D, and D to A and all the concepts and math that goes with it. Information is encoded in signals, increasingly digital signals, which often are communicated via wireless (RF) networks, but there are lots of levels to system architecture from semiconductors to enterprise IT systems. Zoom out, see the big picture, then focus back in once you have a clear view of the fuller picture. The other thought would be to think about where you are going to do an internship and get your first job and what your career trajectory is going to look like. Then circle back and think about whether you want to emphasize Signal Processing or Radio Frequency or both.
Good luck on your earning your EE degree and launching from there!
Remember, as Yogi Berra said, "unless you know where you are going, you could wind up somewhere else." If possible, start with the goal in mind. Then build your plan and work your plan to get to your goal.
