Finally received the wires and put it back together.
Good thing is I am off just by 0.2v at the 8v range when compared to the old 110v primary.
By our calculations we had to double the 4670 turns to 9340. But that was delivering a bit more than expected. I had to add extra 500 turns to bring it down a bit.
The clear coat on just one side of the laminates went fine. Fit not to tight neither loose. Just about right.
The only pain is to deal with 42 gauge wire... too thin to manipulate, to remove the enamel and weld.
It is now measuring a resistor for more than an hour. Still no magic smoke!!! Transformer is cold and reading stable.
I guess that is a winner!
