Well I have to agree with everybody else here the real enemy is condensation. That will eventually ruin even plated tools. For basic hand tools i keep some junkers in the truck. This for two reasons, one is to reduce the value if a theft occurs but the other is that tools suffer from the temperature changes and that is almost elusively due to condensation. So if something is going to go to hell eventually I use stuff from auctions, thrift shops and the like for storage in the truck.
As for electronics I wouldn't keep anything of value in a plastic Walmart tool box. I think I know which you are talking about here (have a few) which have no sealing at all. The same issue applies condensation is just bad. However there are additional things to consider with instruments, for one Alkaline batteries suck for leakage and I'm convinced that the cold and thermal cycles makes leakage worse. Then you have the reality that those instruments will not be immediately usable until they have warmed up.
Hi Folks, hope all is well with you guys!
I leave my Oscilloscope, Arduino Dev boards, multi meter, electronic spare components,spare capacitors, resistors, Arduino sensors modules etc etc, in my car. I leave them in the trunk in regular Walmart tool boxes.
Yeah this is a problem, those regular WALMART tool boxes are not sealed. Some of that stuff I would not worry to much about but the instruments need better care. Honestly if you really need to leave them in the car consider getting cases that seal tight, Pelican or similar and then add desiccant air driers to the case. The case might moderate the thermal cycling some but it should do a far better job with respect to condensation.
At the very least have one case for the instruments and one case for the sensitive assembled components (Arduino stuff). The discreet components probably can survive in standard tool boxes if kept in ziploc bags.
Does the cold weather affect these items if they are left in the car continuously throughout the winter?
I live in the North Eastern part of the US with a Köppen climate classification of Dfa/Dfb.
I would like to have your feedback regarding what you think about leaving electronic stuff in the car during cold winter months.
If at all possible don't do it!!! However if you feel like you have little choice package the valuable stuff in sealable containers. Oh and pull those Alakaline batteries.
I don’t want to move 6 tool cases every evening, out of my car, back into the house. ( Of course, if you guys tell me to move them inside every evening, then I will )
You didn't mention how big your scope was but a modern scope and meter can fit in thick brief case or even a technicians case. Get into the habit of taking that one case in everyday and your biggest risks are minimized. If you want the oil field exec look you could try zerohalliburton.com for a case or if you want purpose built cases check out:
https://www.jensentools.com/search.aspx?f=2%3aJensen+Tools%2c1%3a277. The idea here is to have one and only one case to worry about each day. This shouldn't be any more of a problem than grabbing a brief case or packed lunch.
I use all the above mentioned items, at work randomly. I don’t use them every day, but I need to have them handy in case I need them at work.
Sometimes I work from home at the last moment and leaving them at work is not an option either.
Thank you for your replies!
Well I think you have my line of thought, don't leave the critical or expensive things in the weather. Done right you should be able to get by with one case packed with those expensive and let say delicate tools. I really do not see a huge benefit to pulling everything every night.
Frankly if your scope is an older model it might pay to invest in a thinner more modern one. That would reduce weight and allow for a thinner case.
Back in the day I use to work out of one of those Jensen cases and while not ideal compared to a bench and a proper tool box, it is an excellent mobile solution. You end up with your instruments and hand tools at your finger tips. Just don't throw a lot of iron in there as they can get heavy.
While targeting a different market one source for light weight travel/tool case is Milwaukee available at local hardware stores. They call them their PackOut line of snap together cases. You will not be snapping but you would want one with the interior room to carry your scope. So check the inside dimensions. The snap together nature does result in some loss of vertical height. Milwaukee is probably your best low cost yet rugged solution to a luggage style carry case.
