Hello to all.
I have a circuit of this type (see attachement circuit 1)
where I use a resistor of 12K and a photoresistor LDR. The output of the signal is taken at A and sent to the base of a TIP107 (PNP darlington transistor).
Is there a way to reverse the polarity of the power supply circuit according to an external signal that presents two voltage values so as to have, as in attachement circuit 2 ?
