PWR_FLAG isn't a net name, it's a special "component" (actually, just a flag on a net) that tells KiCad that the net it's attached to is a power net. (Not that they're the same power net. It's literally just metadata saying "I'm a power net".) Apparently, KiCad uses this in ERC when making sure every component is powered.
Thanks. I'll know. I'm just planning to switch to KiCAD this year.
From what? After getting comfortable in EasyEDA and Altium, I find KiCAD to be needlessly complex and fiddly. (Though not impenetrable like Eagle.)
EasyEDA is very similar to KiCad, probably modeled on it and made. But there are already too many glitches and inconvenient moments in it. The last thing I didn't like was hiding the project through some clumsy other site, before it was just enough to choose "share". Direct selection of components from LCSC is very convenient, but increasingly limited and the price is already catching up with Mouser, for example. Altium is very bulky and expensive.
I used KiCad for a long time, but then I used EasyEDA for a long time - I'm drawn back.
Definitely not. EasyEDA is very clearly modeled after Altium. Some dialogs even copy Altium's layout and oddball wording! EasyEDA is nothing at all like KiCAD. (I use Altium and EasyEDA frequently.)
Altium is costly (if you're not in education), and while it does have a learning curve, it still makes more sense than KiCAD or Eagle.
@tooki, Petrukhin, you're really going off topic!
Take this discussion to the KiCAD section, please.
It's not helpful to the OP.
It happens, and it's not entirely off-topic. (Nor would the KiCAD forum be unambiguously appropriate since it's a comparison of packages.)
