Author Topic: Female Connector Question  (Read 684 times)
Offline AddisonAve1938Topic starter
« on: May 21, 2024, 02:08:00 am »
Does anyone know of a new connector (preferably solder) that would allow for a connection to be made with the corresponding male pin? I haven't been able to find one on Mouser or DigiKey. The internal diameter of the female terminal is ~3.16mm - not sure if these are considered barrel connectors.
Here is a photo of the terminal connector(s) in question:
« Last Edit: May 21, 2024, 02:35:26 am by AddisonAve1938 »
Offline wasedadoc
Re: Female Connector Question
« Reply #1 on: May 21, 2024, 10:33:03 am »
Nobody would refer to that as a barrel connector. It is some variety of AC mains connector.
Offline Terry Bites
Online indeterminate
« Reply #3 on: May 21, 2024, 11:02:12 am »
I have seen connectors like that on sowing machines.
Proprietary plugs that are only available from the original manufacture are a pane in the but
Offline ftg
    • ftg's RF hax paeg
« Reply #4 on: May 21, 2024, 11:04:15 am »
I have seen that as the mains connector behind some old test equipment.
One HP pulse generator and one Italian made VHF signal generator.
So I'd also say it's some mains plug, with ground.
Offline m k
« Reply #5 on: May 21, 2024, 12:43:59 pm »
HEWPA-8120-0100 is a Schuko version of a cord, made in W.Germany.
Maybe not completely propriety.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Triplett-YFE
Offline wasedadoc
« Reply #6 on: May 21, 2024, 03:00:30 pm »
sewing
manufacturer
pain
butt
Offline pcprogrammer
« Reply #7 on: May 21, 2024, 03:12:42 pm »
Female Connector Question: Will you marry me.
But that belongs in another thread.
I second that it is a mains connector for some device.
Offline reboots
    • http://reboots.g-cipher.net
« Reply #8 on: May 21, 2024, 03:58:48 pm »
I've done this using brass tubing press-fit over the male pins, insulated with heat shrink. Slitting and squeezing the tubing could add some spring tension. This was for a carefully laid-out bench test--I don't recommend it for everyday use.
What's the OD of the male pin? That's the critical dimension for selecting a mating part.
Offline paultino
  • Country: ee
« Reply #9 on: May 24, 2024, 07:59:22 pm »
This is a Swiss socket.  Type 13.
https://en.wikipedia.org/wiki/SN_441011
Online Benta
« Reply #10 on: May 24, 2024, 08:22:17 pm »
No. The OP's plug is appr. the size used in electric razors etc.
The Swiss plug is far larger.
Online soldar
« Reply #11 on: May 24, 2024, 09:14:16 pm »
Offline Vovk_Z
  • Country: ua
« Reply #12 on: May 25, 2024, 10:40:58 am »
I'm wondering, if there was a site, where connectors of both genders could describe itself, and find an appropriate worthy pair!  :)
« Reply #13 on: May 25, 2024, 10:56:57 am »
Who knows, sometime in the future. Already voices going up about AI marrying.  :palm:
