I am using PIC18F4550 with MPBALX IDE V2.26, Xc8 V1.32.
1. Putting string in ROM/flash: I have lots of strings in my code. I want to put those in flash.
When I use this "rom" keyword, error appears, but if I remove this keyword there is no error. But it places string in data ram, which I dont want. What is solution.
Error:
rom const char table[] = "fggx";
source/global.c:14: warning: (374) missing basic type; int assumed
source/global.c:14: error: (314) ";" expected
nbproject/Makefile-default.mk:158: recipe for target 'build/default/production/source/global.p1' failed
make[2]: Leaving directory 'D:/project/Project_51_ashokji/pic/codes/current_code/V6_lcd/njg.X'
(908) exit status = 1
make[2]: *** [build/default/production/source/global.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
make[1]: Leaving directory 'D:/project/Project_51_ashokji/pic/codes/current_code/V6_lcd/njg.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
BUILD FAILED (exit value 2, total time: 508ms)
Build successful:
2. On successful build, code gives some warning. What is corrupted fast interrupt shadow registers?
:: advisory: (1233) Employing 18F4550 errata work-arounds:
:: advisory: (1234) * Corrupted fast interrupt shadow registers
:: warning: (1273) Omniscient Code Generation not available in Free mode
3. PIC18F4550 datasheet "DS39632E", gives all registers associated with peripheral on last page of that peripheral.
Timer0 on Page 131, Table 11-1, has list of register associated with it.
It also mention TRISA & its bits 0-6.
What is their use in it?
4. I have sizeof various datatypes in compiler. Sizeof float & double comes out to be 3 bytes? What does 3 byte means, it should be 4 bytes.
