Author Topic: Floppy disk drive STEP signal driving a LED  (Read 858 times)
Offline caiusTopic starter
    • Caius Arcade Repairs & Engineering
« on: December 17, 2022, 11:55:53 pm »
Hi all,
I'm trying to drive a LED by the STEP signal (active LOW) of a floppy drive but LED lit briefly when single pulse occur.Do I need to a stretching circuit, perhaps?Can you advice me some solution?Thanks in advance.
Offline retiredfeline
Re: Floppy disk drive STEP signal driving a LED
« Reply #1 on: December 18, 2022, 02:08:08 am »
Yeah you need a monostable. Lots of designs around of which fer shure they'll be a 555 one.
Online Stray Electron
« Reply #2 on: December 18, 2022, 02:52:14 am »
  All you need is a simply Logic Probe circuit.  There should be plenty of circuit designs available online.
« Reply #3 on: December 18, 2022, 11:17:15 am »
Thanks for replies.
The STEP pulse is around 7us as measured by a logic analyzer :
I have in mind the attached designs (without 555 for now), which could be the more appropriate? (RC value must be adapted obviously)
