Author Topic: Fluke 189 series 2  (Read 9210 times)
Offline sabinbpTopic starter
  • Country: ph
Re: Fluke 189 series 2
« Reply #25 on: November 23, 2018, 10:45:39 am »
oh so David was wrong in stating that the 189II was a rebranded 289. It's technically a 287?
there is no difference between the 287 and 289 apart from the accuracy in logging?
does the 287 have LoZ?
Offline gnavigator1007
« Reply #26 on: November 23, 2018, 11:46:15 am »
Did the 189 II  have the same super cap leakage problem as the 289? If you arrange a meet up, I'd definitely ask to open it up.
Offline Mr. Scram
  • Display aficionado
« Reply #27 on: November 23, 2018, 11:58:47 am »
As a buyer that seems sensible, but as a seller I wouldn't have it.
  • Country: ph
« Reply #28 on: November 23, 2018, 12:00:52 pm »
if I can convince the seller to open it up how do I check if the unit has the super cap leakage?
Offline Shock
« Reply #29 on: November 23, 2018, 01:22:24 pm »
If you look at the photo you posted you will notice no LoZ feature. Compare your photo to mine which has a 287 in it.
This document could be a rough guide, remember there could be subtle differences between the short lived 189II and the 287.
http://assets.fluke.com/Catalog2012/1274458T_EN_w_Pg9.pdf?view=FitB
Does the Fluke 189II have the leaking cap?
https://www.eevblog.com/forum/testgear/fluke-189-with-leaking-surface-mount-coin-cell/
« Last Edit: November 23, 2018, 01:24:10 pm by Shock »
The following users thanked this post: gnavigator1007
  • Country: ph
« Reply #30 on: November 23, 2018, 02:22:10 pm »
oh yeah now that you mentioned it. there is no LoZ
