Author Topic: flux advice  (Read 12262 times)
Offline algorithmTopic starter
Re: flux advice
« Reply #25 on: August 11, 2014, 02:08:42 am »
Brilliant, thank you both, very informative.  :clap:
Offline IanB
Re: flux advice
« Reply #26 on: August 11, 2014, 02:15:07 am »
If you try dehydrating it further, it doesn't let the water go easily, and HCl comes off as well, leaving some mix of zinc chloride and hydroxide/oxide.
Apparently this decomposition also happens under the heat of soldering and the liberated HCl helps to dissolve the surface oxide layer on the item being soldered.
Offline KWuensch
Re: flux advice
« Reply #27 on: August 11, 2014, 02:56:02 pm »
It depends on what type of solder or flux you were using for the failed projects. If you are using a no clean wire solder or flux like these:
http://www.gotopac.com/AIM_AF_NC264_5_1GAL_p/af-nc264-5-1gal.htm
http://www.gotopac.com/AIM_AW6337_010NC209_p/aw6337-010nc209.htm
You should be able to leave the left over flux on there since those are non-conductive. However, if you are not using a no clean solder or flux, you should be removing the excess flux when you are finished. You should be able to clean it off with IPA once you have finished soldering.
