When you start getting up into that voltage range, you should be using a 100x scope probe. Normally you would us the 10x probes that (I assume) came with the scope. This gives you,
in theory only, 10 times the maximum voltage handling, i.e. 3000 volts max instead of 300volts, but most 10x probes have a much, much lower maximum voltage rating. Check the documentation that came with the probes. 100x probes divide the voltage by 100 which gives you a very comfortable margin and most 100x probes have a 1kv maximum voltage (again check the documentation). I use 100x probes for my work on vacuum tube amplifier circuits.
Please be very careful around these voltages, as they can be fatal if contacted. Best to connect everything with power off and stand back for testing!
