Hi all,
I just bought a function generator DG1022Z from Rigol.
Is there a way to change the output signal? i connected it on the base of a transistor with a large resistor and i get 250 mv on it. With a 5V pp on the screen. It seems its gives me just 1/10 of the voltage.
Stefan
Hello and welcome Stefan!
1. Can you confirm, that the output is not loaded? (no current flows out of the output)
2. If you measure the voltage with a oscilloscope and a 1:10 passive probe: Can you confirm, that the division rate of 1:10 is adjusted on the scope to compensate the voltage drop?
Well, have you verified that the DG1022 is outputting properly? Connect it directly to a scope, you should see 5 Vpp on the screen. The only setting that would change the display amplitude to match an expected output level when connected to a circuit (specifically 50 ohms) would be the load setting in the utility menu (50 ohms or high Z). But I don't think that is your issue.
