I am modifying a tape recorder to a guitar amp and I already made a simple gain stage going in where the play head was, it has a gain of about 6 (16dB) it's simply a 12ax7 gain stage into a cathode follower.
Why a cathode follower: I dunno. I just thought that I might put some kind of tone control early in the circuit.
the tape player/recorder is a soviet "Sonata-304" (translated letters from Russian)
I am 99% sure I won't find a schematic for it anywhere. so I'm gonna make one later.
I doubt that anyone can help me with getting a "tighter" distortion without any schematic or idea on how the circuit works.
so when I make the schematic I'll post it here so maybe you can help
also, I haven't replaced the caps, it doesn't have ANY 100hz hum, only a bit of 50hz hum. I tried replacing the main filter cap with no change to the noise or tone. I still have the new ones it but they didn't help with anything really.
the coupling caps I believe are all-ceramic. it uses a push-pull output stage with (I'm assuming) 15 watts. it's REALLY loud. it has a ~ -20V_0V_25V supply. I don't know why it's not equal but maybe it's cause I measured across the filter cap relative to ground.
it has 2x 3*6 inch speakers and both are in series and have an impedance of 8Ohms each. so the output impedance is 16Ohms. but I am gonna probably connect a 2x 7inch 6 Ohm speakers that are pretty efficient but they were meant for about 10 watts only so it may distort as it did when I turned it up with another amp.
I can also use 2 HiFi speakers in series with an impedance of 16Ohms when in series.
otherwise, I will need to buy some decent speakers for it.
anyway, I wanted to make it sound decent with the speakers I have.
it just sounds "sluggish"
the tone controls are AMAZING, while they don't do as much with a lot of overdrive, when I have a clean signal, it can flip the sound upside down.
it has a decent gain with the preamp I made and pinch harmonics already "scream" so I'm pretty good with the gain it has.
also, the only cap I had to replace was a 1uF ceramic for the recording oscillator thingy board. but it still doesn't want to record really. it doesn't erase and the record/play head is in terrible shape. also, it plays at the low speed to none of my reels play on it. but I don't intend to use it for reels ever again.
so it would be great if you have any suggestions on making is more suitable for my needs.
as I said I'll make a schematic probably so it's much easier to understand, and put it here.
