Author Topic: Having trouble with relays - coils drawing current, but never switching  (Read 5428 times)
Offline HwAoRrDkTopic starter
I bought some of these micro relays to use in a board I designed:
TE Axicom IME06TS. 12VDC, DPST-NO.
Datasheet: http://www.farnell.com/datasheets/1717939.pdf
I cannot for the life of me get these damn little bastards to work properly! >:(
The thing is, they seem to be working. I can supply the coil pins with 12V, and they will happily sit there drawing 8-9mA. That appears to be within spec; actually measuring the resistance of the coils gives me about 1K, which matches the datasheet. But they don't switch the contacts!
Rarely and randomly - and this only ever happens out of circuit on the bench, and I don't know what combination of circumstance causes this - they will work, and I can hear the 'click' and there will be good continuity between the switching pins. It can be working one minute though, and not the next. And I have not been able to get them to switch at all, ever, when soldered-in on my board.
Is there anything I'm missing here? What else I can check before I declare these parts as faulty and try and get them replaced? Or is there perhaps some way I may have inadvertently killed these relays?
Offline cvanc
Re: Having trouble with relays - coils drawing current, but never switching
« Reply #1 on: November 21, 2016, 09:27:49 pm »
Is polarity correct? Some relays won't work with reversed coil polarity.
^^^This.
Page 2 of your datasheet shows pin 1 of the coil as positive.  Please verify you are driving it thusly.
(and if you feel like saying 'well that datasheet wasn't terribly clear about this', well, you're right  :-// )
Offline Seekonk
« Reply #2 on: November 21, 2016, 09:31:25 pm »
How old are they?  I mean date code. Some relay contacts over time oxidize and don't make contact at low voltage.  Apply a higher voltage and some minimal current the oxide layer breaks down.  Assume you tried the obvious.  I once spent a half hour on the phone with some guy trying to hook a see through plastic relay.  Finally couldn't take aymore.
Offline langwadt
« Reply #3 on: November 21, 2016, 09:35:19 pm »
double check number on the relay maybe you accidentally got the latching version ?
« Reply #4 on: November 21, 2016, 10:19:28 pm »
^^^This.
Son of a *****!!! >:( |O :rant: :palm: :'(
I just tried one with the 'correct' polarity voltage on the coil and it works consistently.
And guess which ****ing way around I have the pins laid out on my PCB? That's right, the wrong way round. |O So much for that batch of boards...
Before I go and drown my sorrows, someone please explain to me why polarised relay coils are a thing, and why the coil itself draws the same current no matter which way round the connection is made.
And FFS, TE. Make it more bloody obvious on the datasheet! And an actual polarity marking on the relay itself wouldn't go amiss either.
« Reply #5 on: November 21, 2016, 10:34:18 pm »
Ah, okay. I guess these relays might need a permanent magnet because of the small size. I suppose such a tiny coil may not have the holding power to make a secure switching contact, so it needs some assistance.
Offline dmills
« Reply #6 on: November 22, 2016, 12:34:39 am »
You might try subbing an IM06DTS which is not as far as I can see polarized.
I think everyone gets stuffed by this at some point (Bit like SMT LEDs where the polarity depends on the colour even within a range)....
73 Dan.
« Reply #7 on: November 22, 2016, 01:34:09 am »
No, I don't think that'd help. The IM06DTS is just a 'high current' version of the DPDT plain-IM part, and the datasheet for those still shows the coil as polarised; not to mention it has an extra pair of pins for which my board has no holes.
I think the entire IM series has polarised coils. :--
Think I might be able to make good my current lot of boards by cutting some traces and soldering a few kynar wires. Gonna be a pain in the backside, though.
« Reply #8 on: November 22, 2016, 01:46:02 am »
73 Dan.
When placing SMD LEDs I no longer use normal component tweezers, I use measurement tweezers with a multimeter on the diode setting.
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #9 on: November 22, 2016, 02:41:27 am »
Make some tiny "adapter" boards that have a pinout on one side that matches your "wrong" PCB and then wires it into your relays correctly.  Then it will look professional. :)   OSHPark is perfect for this, they are very cheap for very small boards and if you send them the files tonight you have it in 10 days in the US at least.  Not sure on how long to UK.
Have You Been Triggered Today?
Offline w2aew
    • My YouTube Channel
« Reply #10 on: November 22, 2016, 03:16:45 am »
^^^This.
If you used a through-hole version of the part, maybe you can mount the relays on the other side of the board.  If so, you can save that batch of boards.
FAE for Tektronix
Offline macboy
« Reply #11 on: November 22, 2016, 03:42:18 pm »
I love this suggestion! Very clever  :-+
The following users thanked this post: w2aew
« Reply #12 on: November 22, 2016, 04:00:14 pm »
Aha, yes! Great idea. :-+ Don't know why I didn't think of that.
Not sure if the board will fit inside the intended enclosure once the relays are mounted on the underside, though - I'll have to see.
Offline bson
« Reply #13 on: November 22, 2016, 06:53:10 pm »
We've all done it.  I remember when I discovered some Omron relays specify pinouts based on a bottom-up view for TH while the exact same device in SMD have top-down pin numbering... :wtf:  I haven't checked the datasheet for your TE device, but if it's TH just mount it on the bottom side for further verification to help find any other board problems so you can fix as much as possible in a single update.
Offline jitter
« Reply #14 on: November 22, 2016, 07:52:32 pm »
Reminds me of when for some product we used polarised Omron relays and the things refused to work...
Everything checked out fine, type and everything, polarity of the layout was correct (as proven in earlier runs). But then I noticed something odd in the printing on the relays that I couldn't find in the datasheets.
The relays we should have gotten were Omron G6B-1114P-US5VDC, but instead we got the G6B-1114P-1-US5VDC.
The difference was "-1" and I couldn't find its meaning in Omrons datasheets (still can't). Than I saw this description on the Mouser page for the "-1"-version: "General Purpose Relays SPST-NO 5VDC Reversed Polarity" and all became clear.
Edit: I think this version may have been a "special" by Omron, hence not finding their way into the datasheet. However, to this day, Mouser sell a reversed polarity version of the 12 V model of the above relay.
« Last Edit: November 22, 2016, 08:01:19 pm by jitter »
« Reply #15 on: November 23, 2016, 01:07:28 am »
I de-soldered all the relays and re-soldered on the underside of the board and everything works fine now. :D
Definitely doesn't fit in the enclosure any more, though. :(
Offline w2aew
« Reply #16 on: November 23, 2016, 03:21:10 am »
At least you can validate proper operation of the rest of your board.
FAE for Tektronix
Offline JoeN
« Reply #17 on: November 24, 2016, 06:12:11 am »
Yes, don't get upset. I always get some stupid errors on my board every and each time I first release the design despite triple checking, and an iteration is almost always inevitable.
Good thing is they usually work the first time, though requiring some genuine bodges and the involvement of quite some flux and micro soldering.
After the first or second sacrificial batches, Murphy don't often get me the second or third time.
I have a pile of PC ISA boards from the old days and back then, mid to late 80s, early 90s, it was not at all rare to see bodge wires on boards that were sold into retail.  It happens.
