Author Topic: HC05 Bluetooth and iPhone  (Read 32098 times)
Offline ludzincTopic starter
    • My Misadventures In Engineering
« on: August 28, 2014, 12:21:25 pm »
Hi All
I've seen a lot a Bluetooth serial modules hooked up to Android devices, but none to iPhones.
I just cannot get my iPhone to detect my HC05 module in Slave / Master mode and I was wondering if anyone:
1.  Has done this and can share the magic or
2.  Has apple screwed me and they don' allow this kind of thing?
Thanks
Simon
Offline ctz
Re: HC05 Bluetooth and iPhone
« Reply #1 on: August 28, 2014, 12:42:18 pm »
ios does not support most bluetooth profiles[1], because apple wants a slice of peripheral profits through its MFi program[2]. If you can't dump ios, you will have to use BLE (which is unrestricted and not part of MFi).
[1]: http://support.apple.com/kb/ht3647
[2]: https://developer.apple.com/programs/mfi/
Offline RenGate
  • Country: ua
« Reply #2 on: August 28, 2014, 12:58:51 pm »
If you are developing your own application for this task, you can check out "Core Bluetooth Temperature Sensor" example. But, as was already stated in previous comment, you better switch to Bluetooth LE capable module.
Offline matkar
  • Country: si
  • Sixty percent of the time it works EVERY time.
« Reply #3 on: August 28, 2014, 09:55:55 pm »
I believe you also need at least Iphone 4S to work. It won't work with Iphone 4 or less.
Offline josem
« Reply #4 on: August 28, 2014, 10:35:13 pm »
You can get the HM-10 module which is very similar to the HC05 and talks Bluetooth Low Energy (BLE) with the iPhone (4S or later), iPad 3 or later, iPod 5th gen, most Android 4.3 phones and latest tablets, Windows Phone 8.1 and Blackberry 10...
« Last Edit: August 28, 2014, 10:37:09 pm by josem »
« Reply #5 on: August 29, 2014, 07:34:18 am »
Thanks all.
I was trying to look at how I could open my garage door with my mobile on the cheap.
Looks like Illl park this project until I get a 'droid!
Offline timb
    • timb.us
« Reply #6 on: August 29, 2014, 07:54:46 am »
Just pick up a Spark Core and do it via the internet? The range on those BT modules is going to be too small to work as a garage door opener.
Sent from my iPhone
« Reply #7 on: August 29, 2014, 08:02:30 am »
Raspberry Pi, wifi dongle, GPIO and web page.
All stuff in my junk box.
Overkill to use an RPi for this, but Meh.
I walk home from the train and periodically forget my house keys. Happy for the range to be 'right next to the door'.
Offline timb
    • timb.us
« Reply #8 on: August 29, 2014, 08:49:22 am »
Eh, RPIs are in the disposable price range these days. (Within $5 of a Spark Core.) So that should work just fine! :)
Sent from my iPhone
The following users thanked this post: jhon321
Offline jhon321
  • Country: pk
« Reply #9 on: April 08, 2017, 08:53:58 am »
I had the exactly same problem i reached here from searching google the solutions from other person helped me alot i will try to find some cheap stuff for this as the op mentioned.
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
« Reply #10 on: April 08, 2017, 11:01:24 am »
I'm successfully using these ones from ST with Android and the datasheet explains how to extend them for iOS compatibility:
SPBT2632C2A (old one, recently marked NRND)
SPBT3.0DP2 (drop-in replacement)
https://www.digikey.com/products/en?WT.z_cid=sp_497_0928_buynow&Enterprise=44&lang=en&Vendor=497&mpart=SPBT3.0DP2
We Are The Watt - Resistance Is Futile!
