Here is my crack at it. I don't know many advanced circuit designs, but a rudimentary design might look like this.
Sensor
Array of bandpass filters (your monitor's accuracy will depend on the filter count and resolution)
Each bandpass output feeds to a smoothing filter to get a measurable amplitude (voltage) for each freq range
Logic circuit which compares the filter outputs (voltage) and identifies the strongest voltage (aka the freq range which the heart rate falls into).
Output of logic circuit is a quantized voltage specific to the heart rate measured. An ADC will "decode" this output voltage giving you the bits you need to drive the display.
The ADC output is run through gate logic to convert to display segment bits.
This avoids programmable controller chips, but after thinking it through, it seems a bit convoluted, no?
Unless this is just a thought experiment in "how could it be done without a ?C", I would say this is exactly why microcontrollers were created, and excluding it from design is like building a skyscraper without steel.
